TwinTurbo.NET: Nissan 300ZX forum - Re: Any codes from the ECU? Idle set correctly?
Subject Re: Any codes from the ECU? Idle set correctly?
Posted by skperkins144 on June 12, 2011 at 7:15 PM
In Reply To Any codes from the ECU? Idle set correctly? (n/m) posted by Crim on June 12, 2011 at 06:51 PM
Message No check engine light except when I forgot to plug the maf in, and unless I accedently moved the idle adjustment screw but I will check it, do I turn it clockwise to increase idle rpm?
